Last Updated on Jan. 20, 2022 |Screen Mirroring
Are you looking for a great screen mirroring application for your smartphone? If that’s true, then consider this article as help at hand. As you read along, you will learn about the best five phone to pc mirror app available. So, ensure that you read this article carefully till the end.
Screen Mirroring is a modern technique that allows you to view all the content of your smartphone on any big screen, for instance, PC, TV, or tablet. However, in order to connect your Android or iPhone to a PC, you will require a phone to pc mirror app.
One of the most efficacious things about using such an app is that you can conveniently watch movies, play games, take up video calls, etc., on your PC screen. Hence, if you’re using any mobile to pc mirroring app, then you don’t have to feel restricted due to the small screen of your smartphone.
Furthermore, you are not required to set up a projector in your home or office to watch anything on a bigger screen. This article entails some of the best options for app to mirror phone to laptop. So, let’s start!
Due to the popularity of the screen mirroring feature amongst smartphone users, you can easily find more than a hundred options of mobile to pc mirroring app. However, not every application or software is good to use.
Hence, in order to simplify your search, we’ve curated a quick list of the best app to cast from phone to laptop. You’ll read about the pros and cons of each so that you can select the appropriate one for your requirements. Check them out here:
Supported Devices: Android and iOS Smartphones
First on the list of mobile to pc mirroring app is AnyMirror. iMobie Inc. launched has launched this brilliant application that enables users to mirror their iOS and Android screens to the PC without facing any challenges. It won’t be inappropriate to mention that AnyMirror is not just a screen mirroring tool because you can mirror your smartphone’s microphone, camera, online media, and other local files on the PC.
Key Features of AnyMirror:
The Main Interface of AnyMirror
Pros:
Cons:
Supported Device: Android and iOS Smartphones
AirDroid is yet another mobile to pc mirroring app that remains one of the top choices for Android and iOS users. This application works as a great toolkit when it comes to controlling the smartphone on a PC. Along with screen mirroring, AirDroid allows you to transfer images, videos, and other files from an Android or iOS smartphone to a PC. You can make calls, send messages, attend remote meetings, play games, etc., via PC.
Key Features of AirDroid:
Use Airdroid to mirror from Android to PC
Pros:
Cons:
Supported Devices: Android Smartphones
If you’re looking for a mobile to pc mirroring app specifically for Android devices, Mobizen is the best option. Though it is a screen mirroring application, you can easily use it for streaming games. You can control any Android smartphone from a PC by installing this app on both devices. It lets you enjoy videos, games, pictures on a bigger screen and control everything through a keyboard and mouse.
Key Features of Mobizen:
Screen Mirror Android to PC by Mobizen Mirroring
Pros:
Cons:
Supported Devices: iOS Smartphones
LonelyScreen is one of the best apps to mirror phone to the laptop for iPhone users. This application allows you to display your smartphone’s screen on a PC or laptop without any cables. You just have to run it on your PC, and the app will communicate with your iOS smartphone via AirPlay. Once you set up the mirroring, you can instantly share and view music, videos, photos from your iPhone on a bigger screen.
Key Features of LonelyScreen:
Mirror iPad to PC with LonelyScreen
Pros:
Cons:
Last on the list of app to cast phone to laptop is Screen Stream Mirroring app. It allows you to mirror and broadcast your Android screen to a laptop or PC in real-time. It acts like a dual-screen where you can share and view videos, photos, and other media live. In order to make the connection stable, it uses a strong Wi-Fi connection. The app has an intuitive interface.
Key Features of Screen Stream Mirroring:
The Mirror App – Screen Stream Mirroring
Pros:
Cons:
Screen mirroring indeed extends the utility of a smartphone. All the phone to pc mirror app mentioned above will help you make the mirroring process flawless. Each app’s key features, pros, and cons are listed here. Hence, depending on your requirements, you can select any app that suits your best.
Get the latest news, how-to and everything from AnyMirror!
AnyMirror How-To Articles
The knowledge base of screen mirroring, video/audio casting, and so on.
