We would like to share some problems we collected.
“How do I cast this video on my computer from my iPad?”
“I need to cast the video from my phone to the computer. Can you help me?”
“I want to cast the YouTube video from my Samsung phone to the computer? Is it possible?”
If you just encountered the similar situation above (unable to cast your videos from your iPhone/Android device), don’t worry. You can try “Online Video Casting” mode to cast the video with a few clicks. The following instructions will help you do it.
Tech Specs
| Windows | Win 11(64 bit), Win 10(64 bit), Win 8(64 bit), Win 7(64 bit) |
| Mac | macOS 10.13 (High Sierra) and above |
| iOS | iOS version 11 and above |
| Android | Android version 5 and above |
| Hard Disk Space | 500 MB hard drive space |
| RAM | 512 MB system memory |
| CPU | Pentium IV 2.4 GHz or above |
| Graphics Card | Accelerated 3D graphics – 64 MB RAM |
| Sound Card | Windows-compatible sound card |
Supported Device Models
| iOS | All iPhone, iPad or iPod touch with iOS 11 and above |
| Android | All Android brands with Android 5 and above |
Benefits for Basic & Standard & Pro Version
| Benefits | Basic | Standard | Pro |
| Mirror Phone Camera to Computer |
Before you perform any functional operation, please get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing AnyMirror on your computer.
At the same time, please keep your iOS device and computer connected to the same Wi-Fi network.
Open AnyMirror and choose “Online Video Casting” function. Then you will see the screenshot below:
Online-Video-Casting-iOS
Let’s take HBO Max as an example: Open HBO Max on your device and play the video you need. Then, please press the cast button
Press the Cast Button
Select AnyMirror_computer name, and tap to cast.
Select Your Computer Name
At the same time, you need to download AnyMirror app on your Android device to help establish connection between Android device and computer.
Firstly, please launch the AnyMirror on the computer. Secondly, please connect Android device and computer to the same Wi-Fi network. Thirdly, please open AnyMirror app on your Android device. Next, please select the “Online Video Casting” option on both your computer and device.
Choose Online Video Casting Mode
Then drag and drop your computer icon to connect when it appears on the AnyMirror app interface on your phone.
Drag the Icon of Your Computer
Let’s take YouTube as an example:
1. Open YouTube on your device and play the video you need.
2. Press the Cast / Share Button and select AnyMirror. (For other Audio & Videos, please press “Cast” button, while for YouTube, please press “Share” button.)
Cast Video via AnyMirror
Due to national and regional restrictions, some Audio & Videos App are not supported currently. We offer our apologies to you for the inconvenience has caused to you.
We'd love to hear how AnyMirror is working for you.
If you're enjoying AnyMirror, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover AnyMirror and motivates our team!
