We would like to share some problems we collected:
“I want to mirror my iPhone camera to the computer, what can I do?”
“Hello, I would like to mirror my Samsung Galaxy A 71 camera to the computer. Can you help me?”
“Hi, my computer camera is broken, can I temporarily replace it with my iPhone 12 camera.”
If you also encounter the similar situation above, don’t worry, you can try our “Mirror Phone Camera to Computer” feature to mirror your phone’s camera to computer with a few clicks. The following instructions will help you do it.
Tech Specs
| Windows | Win 11(64 bit), Win 10(64 bit), Win 8(64 bit), Win 7(64 bit) |
| Mac | 11 (macOS Big Sur), 10.15 (macOS Catalina), 10.14 (macOS Mojave), Mac OS X 10.13 (High Sierra) |
| iOS | iOS version 11 and above |
| Android | Android version 5 and above |
| Hard Disk Space | 100 MB and above free space |
| RAM | 512 MB system memory |
| CPU | Pentium IV 2.4 GHz or above |
| Sound Card | Windows-compatible sound card |
| Graphics Card | Accelerated 3D graphics – 64MB RAM |
| Others | Apple Device Driver (iTunes) |
| Others | USB & ADB Drive ( For Android) |
Before running AnyMirror, you’re supposed to download iTunes to help detect iPhone/iPad/iPod touch.
Supported iOS Device Models
| iPhone Series | iPhone 5 - iPhone 17 Series |
| iPad Series | iPad 5 - iPad 11 |
| iPod touch Series | iPod touch 6 - iPod touch 7 |
Supported Android Device Models
| AnyMirror can support all Android brands with Android 5 and above. For example, Samsung, HUAWEI, Xiaomi, LENOVO, etc.. |
Before you perform any functional operation, please get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing AnyMirror on your computer.
At the same time, you need to download AnyMirror app on iPhone or iPad from App Store to help establish connection between iOS device and computer.
A. Connect Your Device Via a USB Cable.
After completing installation progress, please launch AnyMirror on your computer. And then connect your iOS device to the computer with a USB cable. Then, you will see the interface below. Please choose “Camera Mirroring” and click OK.
Choose Choose Camera Mirroring Mode
When you connect your iOS device to your computer via USB, the software will pop a window “Click “Trust” on your mobile device.” After you click Trust on the iOS device, it will ask you to enter the passcode to unlock the device. Otherwise, your device is unable to be detected.
Click “Trust” on Your Mobile Device
1. If you connect iOS device to the computer for the first time, you need to click “Trust” on your device.
2. If you use this feature for the first time, please grant Camera and Microphone permission on your iPhone/iPad/iPod touch.
And then please select “Camera Mirroring” mode at AnyMirror app on your iPhone/iPad > Select “USB” > Click the “Camera Mirroring” button on your computer> Choose iOS device on your computer.
Choose iOS Device
1. Please make sure you’ve installed iTunes on your computer to help detect your iPhone/iPad/iPod touch.
2. If AnyMirror is unable to recognize your iOS device, you can try to fix this issue by following troubleshooting steps:
① Please download the latest version of AnyMirror.
② Check whether your USB cable is loose. If it is, please reconnect it. If the USB cable is broken, please give a new one a try.
③ Reinstall iTunes.
④ Please log in your computer as Administrator account (For Windows Computer Only).
⑤ If the problem persists, please contact our Support Team for further help.
B. Connect iPhone/iPad/iPod touch to Computer via Wi-Fi.
Method 1. Auto Detect
(1). Please keep your iOS device and computer connected to the same Wi-Fi network.
(2). Launch AnyMirror app on your iOS device and computer.
(3). Click the “Camera Mirroring” option on your computer> Click “iOS”> Click “Wi-Fi”.
(4). Then drag and drop computer icon to connect when it appears on the AnyMirror app interface on your iPhone/iPad/iPod touch.
Drag the Icon of Your Computer
Method 2. Scan Connect
(2). Launch AnyMirror app on your iPhone/iPad> Click “Camera Mirroring” > Select “Wi-Fi” > Select “Scan QR Code” to scan.
Connect the Device by Scanning QR Code
After your iOS device is detected successfully, your device’s camera will be mirrored into AnyMirror. You will see the interface below. Then you can mirror anything captured by the device’s camera to AnyMirror.
Mirror Camera to Computer
You can draw, record the screen and take a screenshot.
Edit the Mirroring Screen on Your Computer
You can front or rear camera, mirror camera, turn off or turn on the microphone on your device.
Edit the Mirroring screen on Your Device
If you want to exit mirroring, you can just click “Exit”.
Exit Camera Mirroring
At the same time, you need to download AnyMirror app on on your Android device from Google Play to help establish connection between Android device and computer.
Please launch AnyMirror on your Android device and computer first. Please choose Camera Mirroring mode on your device.
(1). Please connect your Android device to the computer with a USB cable.
(2). Please turn on USB debugging on your Settings on your device.
Turn on USB Debugging
1. If you need to know how to turn on USB debugging please refer to the page.
2. If AnyMirror is unable to recognize your Android device, you can try to fix this issue by following troubleshooting steps:
② Please check if you have enabled USB debugging option in Settings on your Android device.
③ Please check whether your USB cable is loose. If it is, please reconnect it. If the USB cable is broken, please give a new one a try.
④ Please make sure your Android device can be detected by your computer.
⑤ Check whether you have the latest version of USB Driver and ADB Driver on your computer and device. If not, download and update them from Android device official website.
⑥ If the problem persists, please contact our Support Team for further diagnosis.
B. Connect the Device Via Wi-Fi.
Auto Detect:
(1). Please keep your Android device and computer connected to the same Wi-Fi network.
(2). Launch AnyMirror app on your device and computer.
(3). Click Camera Mirroring on your device.
(4). Drag and drop your computer icon to connect when it appears on the AnyMirror app interface on your phone.
Scan Connect
(2). Launch AnyMirror app on your Android phone/tablet > Click “Screen Mirroring” > Select “Wi-Fi” > Select “Scan QR Code” to scan.
After your Android device is detected successfully, your device’s camera will be mirrored into AnyMirror. You will see the interface below. Then you can mirror anything captured by the device’s camera to AnyMirror.
If you want to exit mirroring, you can click “Exit”.
We'd love to hear how AnyMirror is working for you.
If you're enjoying AnyMirror, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover AnyMirror and motivates our team!
