Sound Settings
“How can I set the sound of the screen?”
“I want to turn the volume up, can you help me?”
If you want to set the sound of the mirrored screen. The following instructions will help you do it.
Step 1. Choose “Sound” Button in the Toolbar.
After connecting phone and computer successfully, you will see the interface below. Then, click the “Sound” button in the toolbar.
Click Sound Button
Click Sound Button
Step 2. Make Settings for Sound Based on Your Need.
You can just slide the button left and right to change the volume. Swipe to the left to decrease or right to increase the volume.
Slide to Change the Volume
We'd love to hear how AnyMirror is working for you.
If you're enjoying AnyMirror, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover AnyMirror and motivates our team!
