“I want to mirror the iPhone screen to the computer, how do I
connect?”
“If I don’t have a USB, how can I mirror the iPad screen to the
computer?”
If you encounter the similar situations above, don’t worry, “Connect iPhone to Computer” guide will help you connect your iOS device to the computer quickly. Please refer to the detailed instructions to connect your iOS device to the computer quickly and easily.
Tech Specs
| Windows | Win 11(64 bit), Win 10(64 bit), Win 8(64 bit), Win 7(64 bit) |
| Mac | macOS 10.13 (High Sierra) and above |
| iOS | iOS version 11 and above |
| Hard Disk Space | 500 MB and above free space |
| RAM | 512MB system memory |
| CPU | Pentium IV 2.4 GHz or above |
| Graphics Card | Accelerated 3D graphics – 64MB RAM |
| Sound Card | Windows-compatible sound card |
| Others | iTunes 9.0 or above; iTunesMobileDevice driver installed |
Supported Device Models
| iPhone Series | iPhone 5 - iPhone 17 Series |
| iPad Series | iPad 5 - iPad 11 |
| iPod touch Series | iPod touch 6 - iPod touch 7 |
Before you perform any function operation, please get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing AnyMirror on your computer.
After completing installation progress, please launch AnyMirror on your computer.
Launch AnyMirror on Your Computer
At the same time, you need to download AnyMirror app on iPhone/iPad from your device’s browser or from App Store to help establish connection between iOS device and computer.
After connecting your iOS device via USB cable, the iOS device will ask you to trust this computer. Once you enter the screen passcode and click Trust and your device is detected, you will see the interface below.
Trust Your Device to Computer
When using AnyMirror app for the first time, please trust the computer on your device. Then please disconnect and reconnect your device to the computer.
Once your iOS device is connected to the computer successfully, you will see the interface below. And you can select the mirroring type to utilize AnyMirror now.
Your Device Is Detected
Please make sure you’ve installed iTunes on the computer to help detect iPhone/iPad.
Connect iPhone and Windows computer to the same Wi-Fi network. Take the screenshot below as an example, please click Wi-Fi (iMobie Free) on Windows computer.
Computer Connected to WiFi ( iMobie Free)
At the same time, please click Wi-Fi (iMobie Free) on your iOS device.
Device Connected to WiFi ( iMobie Free)
After that, your device will be detected automatically. After that, please open Control Center on your iPhone/iPad, click Screen Mirroring button and select “AnyMirror_your computer name“. (Take Screen Mirroring as an example.)
When you connect your iOS device to your computer via USB, the software will pop a window “Trust This Computer?” After you click Trust on the iOS device, click OK on the software, and your device will be automatically detected.
If you select a specific function before connecting the device, it will automatically start the function after the device is read. But if you don’t choose a specific function, just enter the homepage of the software, then once your iOS device is connected to the computer successfully, you will see the interface below. And you can select the mirroring type to utilize AnyMirror now. (Take Screen Mirroring as an example.)
Your iOS Device Is Detected
Connect iPhone and Mac computer to the same Wi-Fi network. Take the screenshot below as an example, please click Wi-Fi (iMobie Free) on your Mac computer.
After that, your device will be detected automatically. And then, please open the Control Center on your iPhone/iPad, click the Screen Mirroring button and select “AnyMirror_your computer name“. After that, your device will be detected automatically. (Take Screen Mirroring as an example.)
We'd love to hear how AnyMirror is working for you.
If you're enjoying AnyMirror, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover AnyMirror and motivates our team!
