Mirror Phone Microphone to Computer
“I want to mirror my phone microphone to my computer. Can you help?”
“The microphone on my computer doesn’t work, but I need to talk on my computer.”
If you encounter the similar situations above, don’t worry, “Microphone Mirroring”mode can help you mirror your phone microphone to computer with a few clicks. Please refer to the detailed guide to mirror phone microphone to computer easily.
Tech Specs
Windows Win11(64 bit), Win10(64 bit), Win8(64 bit), Win7(64 bit)
Mac MacOS 10.13 (High Sierra) and above
Hard Disk Space 500 MB hard drive space
RAM 512 MB system memory
CPU Pentium IV 2.4 GHz or above
Sound Card Windows-compatible sound card
Graphics Card
Accelerated 3D graphics – 64 MB RAM
iOS iOS 11.0 and above
Android Android 5 and above
Others(iOS) iTunes 9.0 or above; iTunes Mobile Device driver installed
Others(Android) USB Driver and ADB Device Driver
Supported iOS Device Models
iPhone Series iPhone 5, iPhone 5s, iPhone 5c, iPhone 6 (Plus), iPhone 6s (Plus), iPhone SE, iPhone SE (2nd Generation), iPhone 7 (Plus), iPhone 8 (Plus), iPhone X, iPhone Xs (Max), iPhone XR, iPhone 11, iPhone 11 Pro (Max), iPhone 12 mini, iPhone 12, iPhone 12 Pro, iPhone 12 Pro Max, iPhone 13 mini, iPhone 13, iPhone 13 Pro, iPhone 13 Pro Max, etc.
iPad Series iPad 5, iPad 6, iPad 7, iPad mini 2, iPad mini 3, iPad mini 4, iPad mini 5, iPad mini 6, iPad Air, iPad Air 2, iPad Air 3, iPad Pro, iPad Pro (2nd Generation), iPad Pro (3rd Generation), iPad Pro (4th Generation), etc.
iPod touch Series iPod touch 6, iPod touch 7, etc.
Supported Android Device Models
All Android brands with Android 5 and above. Like SamSung, HUAWEI, OnePlus, Oppo, Xiaomi, etc..
Part 1. Mirror Microphone of iOS Device to Computer
Step 1. Download AnyMirror on Your Computer.
Before you start mirror phone microphone to computer, please get the AnyMirror downloaded onto your computer. Please make sure the network is stable while downloading and installing AnyMirror on your computer.
1. Please also download AnyMirror app on your iOS device from browser or from App Store to help establish connection between iOS device and computer.
2. Before running AnyMirror, you’re supposed to download iTunes on your computer to help detect iPhone/iPad/iPod touch.
Step 2. Select Microphone Mirroring Mode.
After completing downloading and installing progress, please launch AnyMirror on your computer. Then, please select “Microphone Mirroring” mode.
Please also launch AnyMirror app on your iOS device and choose “Microphone Mirroring” mode.
Step 3. Select iOS Mode.
Please select “iOS” mode bases on the system version of your phone.
Select iOS Mode
Select iOS Mode
Step 4. Connect Your iOS Device to Computer with USB Cable or WiFi.
AnyMirror supports to connect your iOS device to computer with USB Cable or WiFi. You can choose the way as you want.
Method 1. Connect Your iOS Device to the Computer with the USB Cable
Please connect your iOS device to computer with USB cable. After connecting your iOS device via USB cable, the software will pop a window “Click “Trust” on your mobile device.” Once you click “Trust” option on your iOS device, it will ask you to enter the passcode to unlock the device. Otherwise, your device is unable to be detected.
Click “Trust” on Your Mobile Device
1. To use this feature for the first time, please grant microphone permission on your iOS device.
2. If AnyMirror is unable to recognize your iOS device, you can try to fix this issue by following troubleshooting steps:
(a). Please download the latest version of AnyMirror.
(b). Check whether your USB cable is loose. If it is, please reconnect it. If the USB cable is broken, please give a new one a try.
(c). Reinstall iTunes.
(d). Please log in your computer as Administrator account (For Windows Computer Only).
(e). If the problem persists, please contact our Support Team for further help.
3. You can get more info about connecting the device, please refer to Connect Phone to Computer.
Method 2. Connect Your iOS Device to the Computer with WiFi
Please choose Auto Detect mode on AnyMirror and connect your iOS device to computer with the same WiFi. Then, please drag and drop the computer icon to connect when it appears on the interface on your phone.
Drag the Computer iCon to Connect
If your device can’t be connected to computer automatically, you can also choose “Scan QR Code” to connect your device to computer by scanning QR code.
Scan OR Code to Connect
Please launch AnyMirror app on your iOS device > Click “Microphone Mirroring” mode > Select “Wi-Fi” > Click “Scan QR Code”, then please scan the code on computer to connect your device with computer by scanning QR code.
Step 5. Mirror Microphone of iOS Device to Computer Successfully.
After your iOS device is detected successfully, the microphone of your iOS device will be mirrored into AnyMirror. And you will see the interface below. Then you can mirror voice to your computer.
Succeed to Mirror Microphone
What’s more, you can draw on the screen, record the screen, take screenshot, and stream to the live streaming and conference during the mirroring process if you need. You can also mute or enable the microphone on your device at anytime. If you want to exit mirroring, you can click “Disconnect” to exit.
Part 2. Mirror Microphone of Android Device to Computer.
Please also download AnyMirror app on your Android device from browser or from Google Play to help establish connection between Android device and computer.
After downloading and installing, please launch AnyMirror on your computer. Then, please select “Microphone Mirroring” mode.
Please also launch AnyMirror app on your Android device and choose “Microphone Mirroring” mode.
Step 3. Select Android Mode.
Please select “Android” mode bases on the system version of your phone.
Select Android Mode
Select Android Mode
Step 4. Connect Your Android Device to Computer with USB Cable or WiFi.
AnyMirror supports to connect your Android device to computer with USB Cable or WiFi. You can choose the way as you want.
1. Connect Your Android Device to the Computer with the USB Cable
Please choose USB connection on AnyMirror and connect your Android device to computer with USB cable. Once your Android device is detected, please follow the 5 steps on AnyMirror to turn on MTP mode on your Android device and select “Transferring Files”>enable developer options>turn on USB debugging mode>allow “USB debugging” mode when it pops up on your Android device. After that, you device would be connected successfully. You can start to mirror microphone to computer.
Connect Android Device to Computer with USB
1. To use this feature for the first time, please grant microphone permission on your Android device.
2. If AnyMirror is unable to recognize your Android device, you can try to fix this issue by following troubleshooting steps:
(b). Please check if you have enabled USB debugging option in Settings on your Android device.
(c). Please check whether your USB cable is loose. If it is, please reconnect it. If USB cable is broken, please give new one a try.
(d). Please make sure your Android device can be detected by your computer.
(e). Check whether you have the latest version of USB Driver and ADB Driver on your computer and device. If not, download and update them from Android device official website.
(f). If the problem persists, please contact our Support Team for further help.
2. Connect Your Android Device to the Computer with WiFi
Please choose Auto Detect mode on AnyMirror and connect your Android device to computer with the same WiFi. Then, please drag and drop the computer icon to connect when it appears on the interface on your phone.
Scan QR Code to Connect
Please launch AnyMirror app on your Android device > Click “Microphone Mirroring” mode > Select “Wi-Fi” > Click “Scan QR Code”, then please scan the code on computer to connect your device with computer by scanning QR code.
Step 5. Mirror Microphone of Android Device to Computer .
After your Android device is detected successfully, the microphone of your Android device will be mirrored into AnyMirror. And you will see the interface below. Then you can mirror voice to your computer.
What’s more, you can draw on the screen, record the screen, take screenshot, stream to the live streaming and conference during the mirroring process if you need. You can also mute or enable the microphone on your device at anytime. If you want to exit mirroring, you can click “Disconnect” to exit.
We'd love to hear how AnyMirror is working for you.
If you're enjoying AnyMirror, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover AnyMirror and motivates our team!
