Sticky on Top
“I had to open another software, but I still want to view the recording of my iPhone screen, how do I do it?”
“What should I do if I want to stick AnyMirror on top?”
If you want to stick AnyMirror on top, the following instructions will help you do it.
Step 1. Connecting Your Device and Choosing the Function You Need.
After connecting your device, please choose the function you need.
Select Function
Select Function
 Step 2. Click the “Sticky on Top” Button to Put AnyMirror on Top.
 Please click the “Sticky on Top” button. Then even if you open other software on your computer, the AnyMirror windows will still be shown at the top of the screen.
Sticky on Top
Sticky on Top
And you can choose “Remove Sticky” to cancel sticking AnyMirror on top.
Remove Sticky on Top
We'd love to hear how AnyMirror is working for you.
If you're enjoying AnyMirror, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover AnyMirror and motivates our team!
